Originally Posted by lckeehne
I replaced my Duo Therm with Honeywell Digital unit RTH5106D1003.
Works great on 12volt but does NOT work on Shore Power.
Help!!!! Thx
I tried to look up the RTH 5106 thermostat and can't find anything with that number.
Since it works on 12 volts (I assume you mean battery power), that means that it's not the thermostat.
What exactly does it mean "it does NOT work on shore power"? On 12 volts the only thing that should operate off it is the furnace. On shore power the furnace and A/C should work (if they're both hooked to it).
Unless you're removing the battery(s), the thermostat shouldn't know the difference between battery and shore power. Even if the converter isn't working, the battery would still supply power to the furnace until it's dead.
