Old 05-25-2019, 03:04 PM   #1
Thermostat won't change modes
I have a Dometic dual control thermostat. When I turn it on, it opens to the furnace. I am unable to change it to any other mode. I've pulled the fuse and flipped the breakers with no luck. Any suggestions?
Cbcc is offline   Reply With Quote
Old 05-25-2019, 03:21 PM   #2
Iwannacamp's Avatar
Try this...
2017 Puma 297RLSS
Iwannacamp is online now   Reply With Quote
Old 05-25-2019, 10:54 PM   #3
Thank you! Thank you! Thank you! It took several tries but it eventually reset. FF never appeared but an incomplete word did and it worked!!
Old 05-26-2019, 07:19 AM   #4
Iwannacamp's Avatar
Good deal. Glad it worked out.
2017 Puma 297RLSS
Old 05-26-2019, 10:10 PM   #5
Hate to hi-jack thread but.. .
I can't figure out how to start my own, and my problem is with a thermostat.
I have an older Dometic Duo-therm Comfort Control Center that can't be read anymore without the assistance of a flashlight. I cleaned the contacts on the 10 amp fuse that is associated with the system but no help there. The thermostat appears to be functioning normally, but the LCD is just too light to read.
Sandy B is offline   Reply With Quote
Old 05-26-2019, 10:41 PM   #6
Iwannacamp's Avatar
It sounds like a low voltage or bad stat display to me.
Here is a link to the manuals for some of these systems. Not sure this is the right years... I just played on google for a minute. A/Cs are pretty far down. If you donít see it...I guess post a stat pic and we can try to figure it out.
http://bryantrv.com/docs.html
2017 Puma 297RLSS
thermostat
