Old 04-24-2012, 08:57 AM   #1
CamperFan's Avatar
Thought my Concertone had bit the dust.
I thought my Concertone unit had died this past weekend when the unit wouldn't come on after we got set up. The power button still glowed red, but the unit wouldn't power up when you pressed the power button. I took the face off the unit and unscrewed the four screws holding the unit in place. Pulled it out and checked the two fuses I found in there (a double pin automotive type, and a inline fuse in a snap holder). Neither fuse was blown. Put the unit back in and pressed the power button again just in case something had been jarred lose, and the unit powered up and worked fine. I guess the inline fuse wasn't making good contact within the fuse holder.
2008 Rockwood 8265S
2006 Chevy 1500 Ext. Cab LT w/5.3V8 & Tow Pkg.
CamperFan is offline   Reply With Quote
Old 04-24-2012, 04:54 PM   #2
TURBS's Avatar
I think I heard once pulling all the fuses concerning the radio did the trick .
There is also I "believe" a hard reset port .
