Old 07-13-2015, 10:34 AM   #1
cowboy72's Avatar
Three wire Dometic Thermostat change to Honeywell
Hello Everyone
My new 329 BHT 2015 Lacrosse TT has a Black Dometic thermostat which was causing me to many problems.
I would like to change it out with a Honeywell RTH6400 or a Honeywell RTH230 series which I have on hand.
The problem is that both those Honeywell thermostats don't have a high and low fan adjustment just Auto/On also the Dometic only has wires going to it and that is all there is coming out of the wall of the TT. The three wires are red, white and green. I tried hooking it to both Honeywells but couldn't get anything to happen.
Any help would be much appreciated.
Thank you
Rob
cowboy72 is offline   Reply With Quote
Old 02-09-2016, 06:59 PM   #2
kark0202's Avatar
Did u find a solution? I want to get rid of my dometic too. No ambient air temp which i would like.
kark0202 is offline   Reply With Quote
Old 02-09-2016, 07:24 PM   #3
I go RV'ing not Camping
jgourlie's Avatar
From my understanding that dometic can't be changed out. I have the same one and am hoping to ditch it also.
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 02-09-2016, 08:53 PM   #4
Connect green wire to G, white wire to W and red wire to Rc/Rh (with jumper wire in place between Rc/Rh). You will have only one fan speed.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is online now   Reply With Quote
Old 02-10-2016, 05:21 AM   #5
kark0202's Avatar
Sorry but what does a jumper wire mean?
Old 02-10-2016, 06:39 AM   #6
hammer55's Avatar
connect the terminals rc& rh together with a wire
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 02-10-2016, 12:59 PM   #7
Exactly as hammer55 says.
2007 Surveyor SV230
Old 02-10-2016, 02:23 PM   #8
kark0202's Avatar
Do u get high or low fan speed?
Thanks for all the help.
Old 02-10-2016, 02:54 PM   #9
Should be high fan speed.
2007 Surveyor SV230
Old 02-10-2016, 06:21 PM   #10
Originally Posted by cowboy72 View Post
Hello Everyone
My new 329 BHT 2015 Lacrosse TT has a Black Dometic thermostat which was causing me to many problems....
What problems exactly? And I have a high and low fan on the A/C, don't you?
Modmike is offline   Reply With Quote
dometic, thermostat
