Old 03-25-2014, 04:11 PM   #1
Turning on the heat
I am new to camping and bought a forest river (salem) rv camper. It was winterized and I have been cleaning it for the upcoming year. How do I turn the heat on? I have electric hooked up but I die gauged the propane last fall. When I plug the unit up, the heat kicks on but then quickly turns off. If I turn the temp gauge up on the thermostat it does nothing...any ideas?
Tony Smith is offline   Reply With Quote
Old 03-25-2014, 04:14 PM   #2
Kaadk's Avatar
The furnace only runs on propane. If you have it disengaged, then the furnace can't run.
If you're just cleaning it at home, a small portable electric heater and an extension cord should be all you need. I recommend the cord over plugging into the trailer's electric as they can be pretty power hungry and might overload the circuit while you have other things turned on in the trailer.
Old 03-25-2014, 04:16 PM   #3
Someone else posted while I was writing mine.
You need propane flowing to get the furnace to light.
It may take a couple of try's to get the air out of the lines once you hook the propane up.
Mark B.
2021 GMC 1500
Anderson WDH
markb5900 is offline   Reply With Quote
Old 03-25-2014, 04:17 PM   #4
TURBS's Avatar
After you do hook back up the propane it'll take several several starts to get the air out of the system.
TURBS
Sabre owners united!
Old 03-25-2014, 04:38 PM   #5
Light the Kitchen stove,when it lights turn on the Furnace! Youroo!!
Old 03-25-2014, 05:40 PM   #6
Fixed perfectly...Thanks. I just needed to turn the propane on...Thanks again...T
Old 03-25-2014, 06:22 PM   #7
vasnipe's Avatar
Gotta love simple fixes!
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 04-06-2014, 11:28 PM   #8
My heat doesn't come on even with propane? What else am I missing? Turned thermostat all the way up, nothing. Stove top burners all work fine. Yet no heat, any ideas?
MWJ1964 is offline   Reply With Quote
Old 04-07-2014, 12:06 AM   #9
Lots of thermostats also have a tiny on off toggle
Mine was on top
Nothing works with that off
Otherwise it could be bad thermostat
I had one and took it off and crossed the wires and furnace worked fine
Enconcapt is offline   Reply With Quote
Old 04-07-2014, 02:03 AM   #10
bikendan's Avatar
it would if you posted year, make and model of RV or put that info in your signature.
different RV's have different furnaces and thermostats.
Old 04-07-2014, 06:34 AM   #11
Its a forest river 2013 grey wolf 27bhks
The thermostat has the on/off toggle on top.
