Old 01-11-2012, 12:34 PM   #1
TV
In the middle of a Mod and because of the design of trailer cab I am looking to see if any manufacture makes a 30 inch LCD TV. Anybody ever find one?
Portagie1968 is offline   Reply With Quote
Old 01-11-2012, 01:30 PM   #2
buffalohunter's Avatar
I haven't. There seems to be 27" then a jump to 32". Don't know why. Good luck with your quest.
buffalohunter is offline   Reply With Quote
Old 01-11-2012, 01:32 PM   #3
Most Televisions are measured diagonally, so what are your true measurements? Height and width? Then we can help with the diagonal dimension to see what will fit..
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 01-11-2012, 04:15 PM   #4
rracer5's Avatar
Yup, most jump from 26" class to 32" class. Another thiing to watch out for is, a 26" class Tv with speakers on the side, will probably measure around 30" wide give or take. One with bottom speakers (I have 2 26" class Tv's with bottom speakers) will be in the 26" to 27" range across. So, it's probably better to just take your tape measure and walk into Best Buy, H H Greg, or Sears and just start measuring.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-11-2012, 06:00 PM   #5
We have found 27's but why in the world do they not make 30's.
Old 01-16-2012, 03:59 PM   #6
PINTO
Kpinto's Avatar
The newer TV's are not measured diagonally (at least the last one I bought was not) (SANYO) so be careful with how they are measured. best bet is carry a tape measure with you to the TV store.
PINTO
2011 Fuzion 325
2015 Duramax Diesel
Chevy 3500 LT Dually
Kpinto is offline   Reply With Quote
