Old 04-03-2014, 07:03 PM   #1
TV - 2014 Grey Wolf 19RR
Does anyone know if the roof top antenna on the 19RR raises up and or turns to get tv stations? I don't see anything on the inside ceiling ( crank ) to raise it up....I am having trouble getting any stations.
garytravel55321 is offline   Reply With Quote
Old 04-03-2014, 07:09 PM   #2
no it is a stationary digital antenna with a power booster.
maybe its not hooked up properly. I don't know much about them to be of any help.
jgroff is offline   Reply With Quote
Old 04-03-2014, 07:35 PM   #3
GLCM Warrior
Lefty59's Avatar
Most of the digital TVs sold today require you to run a channel scan before they will tune in any stations. It should be in the menu system for the TV.
If you're using an older analog TV you will need a converter box to go with the TV to receive any stations.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 04-04-2014, 08:47 AM   #4
TV - Grey Wolf 19RR
Thanks for all your input....was as simple as setting AIR-ANTENNA on the menu and running channel scan.
2014, grey wolf
