Old 08-23-2014, 08:39 PM   #11
trailer is sitting next to my shop and plugged in to an outside outlet with a 12 ga extension cord. what would cause the tingling? I'm pretty sure it isn't static electricity as damp as it is here.
scout3351 is offline   Reply With Quote
Old 08-23-2014, 09:04 PM   #12
fonzie's Avatar
Probably miss-wired receptacle or extension cord, somewhere hot and neutral most likely reversed.
Fonzie
Old 08-23-2014, 09:17 PM   #13
"Probably miss-wired receptacle or extension cord, somewhere hot and neutral most likely reversed."
So you are saying something in the shop is miswired? If that is the case then this probably isn't part of the problem with the radio and tv as that problem exists when on the generator too.
Old 08-23-2014, 09:23 PM   #14
Ford Idaho's Avatar
Is the ground prong there ?
I would run a continuity test on the cord first.
With the same extension cord that you are using now?
Old 08-23-2014, 09:35 PM   #15
Just grabbed a flashlight and checked cord - no ground prong. When using the generator I use the 50 amp cord with adapters. The cord on it now at the shop stays home when we go.
Old 08-23-2014, 10:30 PM   #16
BooBoo23's Avatar
I'm going to go through everything tomorrow and hopefully can find something. I was working on relocating my LP tanks tonight and was soaked from the heat and humidity. I was kneeling on the ground and leaning against the tongue and was getting a little tingling where I touched the trailer. Anywhere I touched ground and the trailer I got bit. Could this be part of the problem?
For the tingling you got you might search "shocked by frame to ground" on this forum. That may be your problem there.
As to the picture breaking up could be weak TV signal. Digital over the air needs a good clean signal or it will act up. Even a rain storm or other weather event between you and where the signal is coming from can cause a picture problem. The old analog signals would tolerate it but digital will not. In my trailer the tv signal acts up when I use the microwave. DW discovered that when I was heating something up and she was watching the tv the picture went goofy. Apparently the microwave mfr in China slide past the rf emissions test. I know it says Dometic on it but it isn't made by them, just has their name on it.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 08-24-2014, 10:07 PM   #17
Checked cord for ground prong as suggested by Ford Idaho. No ground prong. Swapped in a different cord. No more bite. Thanks for the help guys. Now, the TV and radio thing is still going on so feel free to give advice. We are leaving Tuesday AM for the week in the woods so I won't have access to the internet till next Monday.
radio
