Originally Posted by camaraderie
4. If none of that works...try using a conventional bulb in the fixture.
These fixtures don't have sockets - you can't put a bulb in them. Replacing the entire fixture is the only real option.
We have the same model as the OP. Never used the tv with the antenna, but for sure the LED's screw up the radio reception. The closer the light fixture is to the radio, the more noticeable the effect.
I know the newer Roo's/Shamrocks have a different LED fixture. Curious if they have the same issue. For the radio, we have gotten around that by streaming instead of using the radio. Not as easy to do that for video.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
