Old 02-09-2017, 03:03 PM   #21
Dahagen
Some of the cheaper LEDs will cause the problem!
dahagen is offline   Reply With Quote
Old 02-09-2017, 03:44 PM   #22
Boxer
have same problem its the cheap antenna i think my has a 12volt amp on it if you turn on any 2 lights no tv its not in battery or converter i put an extra 12volt battery on mind thinking amp draw was a problem got to be the antenna
NED AND SHARON HOLCOMB is offline   Reply With Quote
Old 02-09-2017, 04:03 PM   #23
Flybob's Avatar
LED modules consist of LED chips and radio frequency components that generate the voltage and current the LED chip requires. The cheap modules use cheap components that radiate signals that interfere with the tv signals.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-09-2017, 04:18 PM   #24
KMP44's Avatar
Originally Posted by camaraderie View Post
4. If none of that works...try using a conventional bulb in the fixture.
These fixtures don't have sockets - you can't put a bulb in them. Replacing the entire fixture is the only real option.
We have the same model as the OP. Never used the tv with the antenna, but for sure the LED's screw up the radio reception. The closer the light fixture is to the radio, the more noticeable the effect.
I know the newer Roo's/Shamrocks have a different LED fixture. Curious if they have the same issue. For the radio, we have gotten around that by streaming instead of using the radio. Not as easy to do that for video.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
KMP44 is offline   Reply With Quote
Old 02-09-2017, 04:44 PM   #25
I only checked it with four out of the seven or eight lights that are in the camper. I really did not feel like trouble shooting the problem right then since I got the channel to coming finally and only felt like watching the superbowl. One of the lights was the furtherest and another was the closest to the antenna. All of them affected the reception.
erikmpower is offline   Reply With Quote
Old 02-09-2017, 06:59 PM   #26
BuckeyeChuck's Avatar
Cheap LEDs are your problem. You may have to replace the entire fixture or fixtures. It will only effect weak TV signels.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 02-09-2017, 07:24 PM   #27
Not only the lights, but on my new 2016 Shasta FQ185 when I run my power awning in or out my tv also looses signal. Thinking it might have something to do with the wires close to the coaxle mabee ?
Decon Blue is offline   Reply With Quote
Old 02-09-2017, 07:56 PM   #28
Left Coast
Not unless the coax cable or ends are bad..
Old 02-09-2017, 08:41 PM   #29
Here is an example. I work in this field. The over the air broadcast for example in my area channel 4.1 is broadcast on frequency 129mhz, most over the air channels are between 111mhz and 231mhz. LED lights emit frequencies that could disrupt the signal over the air if there are loose or poor connectors or poor shielding on the antenna or junk LED light as described. Same thing in your house if your internet is running crappy or your tv is pixilating. Ingress kills RF signal. Lower the frequency the worst.
2017 FR Wildwood 201BHXL
2013 Ford F-150 King Ranch Ecoboost
zorky is offline   Reply With Quote
Old 02-09-2017, 09:43 PM   #30
HerveVR's Avatar
By the way ERIKMPOWER, if you missed the game:
Patriots 34 Falcons 28 in OT
HerveVR is offline   Reply With Quote
Old 02-09-2017, 10:03 PM   #31
Evereddie's Avatar
There are filters you can install that will fix this but between the filter cost and hours of labor, probably better to replace the lights. (they're called RF filters ) I talked about this at length a while back but am on cell phone right now with limited time and internet service, can't find it searching. . I'm in Japan visiting daughter who just had our first Grandchild! I'll be at computer tonight and should be able to find it then.
Evereddie is offline   Reply With Quote
Old 02-10-2017, 01:02 AM   #32
Cheap LED bulbs are usually the problem. They create RF interference.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 02-10-2017, 05:44 AM   #33
I have the exact same thing. I replaced the bulb in the porch light with LED. Light on...signal loss...light off...perfect picture.
Les & Heidi Kramer
2021 Jayco Melbourne 24L
Olmsted Township, OH
cpd1343 is offline   Reply With Quote
Old 03-19-2017, 09:22 PM   #34
I have a Rock wood mini-lite 2306. I had a problem which drove me crazy for a long time and finally figured it out. Yes. The LED lighting was the problem. We have a very strong local channel (10) which is totally eliminated every time ANY internal LED light fixture was turned on. It only affected this channel but may have affected others if we had them in our area. Channel 10 operates from 192 to 198 MHz. Assuming that the LED driver circuits operate on a similar frequency or a sub harmonic of that. Since 90 % of the internal lighting is LED I never looked into the fix. But these LED drivers that are being used in some Forrest river products blast out RF that messes with tv reception.
Netcomdude is offline   Reply With Quote
antenna, light
