Old 08-29-2013, 11:20 AM   #1
Winnipeg,Manitoba-Canada
pdchristensen's Avatar
TV Antenna Removal
Has anyone removed their exterior "crank up" TV antenna ?
We removed the TV from our unit and don't see much point in having the TV antenna. Just wondering if there is an easy disconnect point without compomising the water tight seals to the trailer.
2015 Rockwood 2306 MiniLite
2012 Chevy Traverse
2011-2014 - 50 nights
Paul, Darcie, Li & Yan
pdchristensen is offline   Reply With Quote
Old 08-29-2013, 12:01 PM   #2
Paul, it's usually a good idea to tell us what RV you have. Putting that into your Signature and/or Profile information is good.
Assuming you have a Winegard instead of a Jack or other brand, here is the manual. Look at step 6. Seems like you could just take the head off.
Old 08-29-2013, 08:03 PM   #3
I would definitly not try to remove the whole outside antenna as there will be a lot of holes to patch up
jako is offline   Reply With Quote
Old 08-30-2013, 10:52 AM   #4
thanks for the response.
To Note; My rig is in the signature - 2013 Vibe 6504
2012 Chevy Traverse
Old 08-30-2013, 10:58 AM   #5
Fulltime family RVer
I wish I understood when/how the app decides to show signatures. I had to go to the site to see yours.
ependydad is online now   Reply With Quote
Old 08-30-2013, 11:06 AM   #6
I think you can only see signatures on the forum.
-assuming the user control panel "CP" signature option is used and the "edit options" - "thread display options" are set to show signatures.
2012 Chevy Traverse
Old 08-30-2013, 11:08 AM   #7
The app shows some, sometimes, but not most. It's really weird.
ID:	38900   Click image for larger version
Old 08-30-2013, 11:09 AM   #8
X2
Old 08-30-2013, 11:36 AM   #9
Dave_Monica's Avatar
If you really want to remove the antenna, here's a link to the installation manual from Winegard's site. Should be able to determine how to remove from these instructions... http://www.winegard.com/kbase/upload/2451808.pdf
I'd cover the area with piece of galvanized plate installed with butyl tape and lap sealent and/or eternabond tape.
Dave
antenna
