Old 09-08-2016, 02:01 PM   #11
Check out Winegard SensarPro TV Signal Meter either at Camping World or Amazon. Yes there is a cost but mine works great
2014 MiniLite with
Nissan Frontier
Stlcaly is offline   Reply With Quote
Old 09-08-2016, 07:56 PM   #12
Be sure you booster is on, if you aren't getting a good signal, rotate your antenna 360 degrees. There is front and back to the antenna.
Good luck.
tomrob1161 is offline   Reply With Quote
Old 09-08-2016, 08:55 PM   #13
TandSH's Avatar
Good luck.
I believe you want to make that 180 deg.
2016 Flagstaff 8528IKWS Diamond Pkg.
2016 F-250 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
TandSH is offline   Reply With Quote
Old 09-08-2016, 09:05 PM   #14
TandSH's Avatar
Originally Posted by fella10 View Post
what I do is,.......if we've never been in this cg, first I'll look at the surrounding rv's to get an idea of what direction most of them use,... I'll dial that in and then its truly trial and error to fine tune for the best reception,....
+1
Old 09-08-2016, 09:12 PM   #15
Originally Posted by dcheatwood View Post
And know which way the antenna needs to be turned to be "pointing" the right way. I went a few years thinking the old batwing should be lined up with the transmitter. Then found out it goes perpendicular to the transmitter. Duh!😟
Are you saying to not point the end of the antenna at the tower but rather set it "broadside"?
Cedar Creek Lake, Texas
2016 Wildwood Xlite 171 RBXL
2016 Ram 5.7L crewcab.
CedarCreekWoody is offline   Reply With Quote
Old 09-08-2016, 09:15 PM   #16
Which way do you point the Jack antenna? I point the arrow head away from the strongest signal.
Old 09-08-2016, 11:52 PM   #17
Professional Texan
TexasBob's Avatar
I have an app on my phone that tells me which way to point for each individual station the area I'm located. It is free It is called OTAMap
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 09-08-2016, 11:55 PM   #18
Professional Texan
TexasBob's Avatar
Here is a screen shot
Texas Bob
Old 09-09-2016, 06:44 AM   #19
We use an app on the phone called "DTV Antennas". It uses the GPS on the phone to locate you and then provides a list of all stations within a distance you set with network affiliation and an arrow point out which direction from your location they are. In the Google Play Store, it is listed as "Digital TV Antennas" and the developer is Nicolas Lichtmaier. Not sure if it's available on other platforms.
The Gisters
TT: 2015 Oasis 310K
TV: 2014 Nissan NV 3500HD-12 psgr Van
The Gisters is offline   Reply With Quote
Old 09-10-2016, 08:26 AM   #20
I have a Direct TV dish and a King HD antenna. Last night found out why I could only get three over air channels. Direct TV receiver was still on. (Trees blocking sat signals) Turned receiver off, got 18 channels.
pdqparalegal1 is offline   Reply With Quote
antenna
