Old 09-03-2014, 11:37 AM   #1
UpNorthMgoBlue
dlzeller's Avatar
TV Booster
I know I have seen a post before about the booster not working on the TV Antenna, but I can't find it. When I push in the booster button, nothing happens, is there a fuse I need to check, or is it more than that. Thanks
David Zeller
2013 Ford F150 5.0
2007 30' Wildwood
dlzeller is offline   Reply With Quote
Old 09-03-2014, 11:39 AM   #2
If the LED lights it's probably working.
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 09-03-2014, 12:09 PM   #3
UpNorthMgoBlue
dlzeller's Avatar
No led light, that what makes me think something is wrong. I pull apart the unit and it all looks intact. However I am an insurance salesman, not an Electrician LOL so what I say really means nothing to me.
David Zeller
2013 Ford F150 5.0
2007 30' Wildwood
Old 09-03-2014, 12:55 PM   #4
I would check the 12 volt fuses first. A blown fuse will have a red led lit next to it. If they are all good open up the booster plate and make sure the 12 volt wires are connected. I would invest in an inexpensive volt meter to check for voltage. After that it gets complicated.
Old 09-03-2014, 07:50 PM   #5
ndickey's Avatar
There should be a fuse in your fuse panel. Not sure what amp, but there is one.
N.A. and Candy
Boomer, Moochie, Cubbie and Banjo
(the camping Maltese)
'08 Roo 21ss
'06 F150 5.4 Triton
ndickey is offline   Reply With Quote
