Originally Posted by Rich5117
I would also check the amplifier, just because the green light is on does not mean you are getting an amplified signal.
The wall plate is not the amplifier; it is the power supply for the amplifier that is physically located in the antenna housing on the roof.
The wall plate is also a manually controlled RF switch that routes power from the supply while it orients the RF feed from the roof antenna (green light on) or depowers the power supply and orients the RF feed from the park cable input (green light off).
