TV cable up
We are the third owners of a 2016 Flagstaff Classic 832 IKBS trailer. I am trying to sort out the correct cabling to 1) watch TV from the antenna, 2) watch TV via the external cable hookup and 3) watch DVD's via the IRV 66. I have reviewed the electronic Owner's Manual on the Forest River site, and find it lacks any details on this topic. I have attached two pictures of our trailer's available coax connections as well as the back of TV as of today. Cabling to the back of the TV is 1) coax, 2) HDMI cable, and 3) and smaller blue cable with what I assume is some form of audio input connector.
We can raise the Wingard and watch TV with good picture and sound once the TV does its channel search, so #1 is fine in terms of hardware as currently connected. And clearly the coax that goes to the TV right now is somehow connected to the Wingard antenna.
We can watch a DVD via the IRV66 with good picture and passable sound, so #3 is again possible with the hardware and current cabling from the wall to the TV. The IRV66 is a poor substitute for a DVD player (at least our model) as one cannot do anything but hit play and stop. But we can see the movie. The sound is quite loud and cannot be turned down to "low" even at a level of 1. The zone sound buttons do work fine.
My issue is understanding what Forest River intends with the two coax plates vs. what they installed out of the wall. Right now there is no way to use the external campground cable without disconnecting the coax from the wall to the TV, and running a new coax from the wall plate to the back of the TV. I do know to push the little black button on the plate to turnoff the green light to switch from trailer antenna to external cable.
What are others doing with this setup? Do you disconnect cables and hook up others when you want external campground cable? I expect my connections are reasonably standard on ca. 2016 Forest River trailers.
Thanks for the help. Tried searching the forum as I know this is a routine question, but I cannot get a set of search parameters that focus on my question, so I get over 1000 hits. Woof.
Larry
Larry & Paula, Houston
2018 2500HD Crew Cab diesel
2016 Flagstaff Classic Super Lite 832 IKBS
Blue Ox WDH
