Old 05-16-2016, 09:36 AM   #1
TV connection
I need help to connect my tv to my genesis 2.0 system. we bought a used palomino puma toyhauler, tv was not included. We purchased a tv, can watch regular channels via antenna, radio on genesis works, if dvd put in genesis, the sound plays, but I do not know how to connect TV to genesis for video. We have 3 plugs coming from cabinet that genesis is in, aux/cable, antenna on one plate. Below is another connection that says TV video out. Not sure what type of cable to use and where to plug. Can someone please help with this basic question?
toyhauler2012 is offline   Reply With Quote
Old 05-16-2016, 11:34 AM   #2
The tv video out should be an RCA plug. You should also have a component video in on the tv. you need a cable with two RCA plugs. It connects between the video out of the A/V unit and the video in on the TV. The plugs should have a yellow insert.
Gotta go campin!
Old 05-16-2016, 05:35 PM   #3
Thumbs up
Thanks for the info, tried it, not working right, also unit will not turn off. So not completely functional. We have ordered a new Jensen unit, awaiting arrival.
Old 05-16-2016, 05:51 PM   #4
Flybob's Avatar
A pic of the connections on the back of the DVD/Radio and the tv would help. If the audio is using a red and white connector, then video is most likely on the yellow connector using an RCA cable.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
