Old 05-04-2014, 04:43 PM   #1
member
Tv connections ??
How does it work? I have a sat and a cable input on the out side. I have a sat/aux and a tv out put in the living room and a tv out put in the bed room. Does that mean that the bed room only gets antenna signal? And if I hook up cable or sat. it will only work in the living room. If so how do you get sat or cable to bedroom the easiest way? Thanks.
2019 Cedar Creek Silverback 31IKS
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 05-04-2014, 05:20 PM   #2
Herk7769's Avatar
Getting SAT to the bedroom is problematic since it is a "homerun" from the outside SAT connector to the SAT/AUX connector in the living room.
Cable is no problem since the camper is wired to route that outside cable connector through the powered source switcher. Just press the black button to toggle between roof and cable inputs.
Light ON - Roof Antenna to entire camper
Light OFF - Cable to entire camper.
See attached manual
HAM CALLSIGN - KC3FFW
Old 05-04-2014, 07:24 PM   #3
member
so how about putting a splitter on the second tv output and then run a coax from sat receiver to the splitter and run tv1 on hdmi and tv 2 coax one at a time no?I am just thinking out loud. Thanks for the info
Old 05-04-2014, 07:59 PM   #4
Herk7769's Avatar
You will need to "home run" another sat only cable to the bedroom and use an A/B switch of some kind.
You can not use SAT in any way mixed with the signals from the main antenna switcher.
HOWEVER, there is a way to get SAT to the bedroom using the existing cables by using a mod similar to this one:
(I also attached a Solid Signal working paper on Direct TV...)
