Old 03-15-2013, 08:16 AM   #11
I used to have the same problem. Took me forever. You're missing the essential tool: signal meter. I bought the Triplett version from Amazon.
The problem is that the receiver itself is too slow to respond to a new signal. With that meter, you can do it almost instantly. (I also have the DP AR app for iPhone which gets me started.) I seldom need to change elevation or skew. With the meter, I can usually do that just by changing the level of the tripod legs.
Old 03-15-2013, 08:22 AM   #12
TURBS's Avatar
Correct
Old 03-15-2013, 08:43 AM   #13
Good stuff thanks
Hawg Hunter is offline   Reply With Quote
Old 03-15-2013, 09:31 AM   #14
Poppy94's Avatar
i just put my dish receiver in the TH, plug into the factory entertainment center system, connect my winegard carryout, hit a switch and a couple of buttons, and BAM......tv on demand. <10 mins. .
makes momma happy to watch the Texas Rangers and Fox News when out and about. low maintenance and easy set up! double bonus for me.
Poppy94 is offline   Reply With Quote
Old 03-15-2013, 09:35 AM   #15
cpaulsen's Avatar
Forgot to mention.....my dish was free....came from a cable company who installed cable to a house and the owner wanted the dish gone.
cpaulsen is offline   Reply With Quote
Old 03-15-2013, 11:46 PM   #16
DougP47's Avatar
Here is a pic of my satellite mounted.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 03-16-2013, 01:36 AM   #17
Indy Steve's Avatar
Originally Posted by f1100turbo View Post
I've had to redo azimuth and skew plenty my friend.
I change it before I even leave so when I get there.
Setup tripod
Level
Aim
Watch tv
Ps I installed my first satellite dish in 1995-ish.
And my parents had one of those 16' "dishes" back in the 80's
16' dish, my parents had it also...how I miss the non-scrambled, free channels available then as a teenager.
Indy Steve is offline   Reply With Quote
Old 03-16-2013, 03:23 AM   #18
Doug P47, how do you get a signal if the dish is mouned to our roof and you are parked under some trees ? Thanks
Old 03-16-2013, 07:22 AM   #19
Directv
Went to camping world and had them install a covered dish on the roof that works in all kinds of weather and you don't have to go up on the roof with the broom to remove the snow. Were hooked to the the to recievers from the house and still using the progaming from the house. Hated going to campgrounds and hoping their cable systems worked or not.
grizz427 is offline   Reply With Quote
Old 03-16-2013, 08:13 AM   #20
TURBS's Avatar
He doesn't prolly get a good signal parked under tree's.
Good reason not to have it mounted I guess.
Turbs
