Old 03-14-2013, 09:48 PM   #1
Question TV ? Dish, Direct, Tailgater, or Carryout
Ok, let the discussion begin, I've got Dish, their customer support is great but hitting that dot many miles away takes me forever. I'm considering Direct , or a Carryout so I can use 2 receivers. I know the stipulations with Carryout. Tailgater out of question because my wife and I come college football season will need two separate TV's. I just bought a used DISH satellite 1000 with a portable tri pod stand and 200' of cable for $75. I already have the 211k recievers from my 1st camper. Took me about 2 hours to get set up this past weekend my best time so far in a year and a half is about 45 mins. Not a good thing. Somebody give us some good suggestions please. Thanks and have a happy St Patty's Day!!
Hawg Hunter is offline   Reply With Quote
Old 03-14-2013, 10:42 PM   #2
On the Dish Remote, do you go to the Dish MENU-SYSTEM SETUP--INSTALLATION-POINT DISH for the location you are in? It gives you the specific skew, azimuth and elevation. A signal meter is also a very handy, time saving gadget also. I can set mine up and start watching tv usually within 20 minutes from start to finish. A level is also a must to make sure the pole is vertical. I use a steel tube with 3 adjustable legs on it and set a bubble level on the top of the tube and adjust the individual legs accordingly. If the tube is not vertical, you can fight it for hours as the skew & elevation will just be a 'hit or miss' situation.
Old 03-14-2013, 11:16 PM   #3
DougP47's Avatar
I have the tailgater sat receiver. It it mounted to the tt. I hoke up the generator and get the tv turned on power the receiver and scan saturate up and running in 2 minutes. Sweet.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 03-15-2013, 02:40 AM   #4
Thanks DougP47. I have a 2011 Dodge 1500 5.7 Bighorn. I pull a Rockwood 2604 RL. My MPG is 11-12. Pulls and stops great. How is yours ? Thanks
Old 03-15-2013, 02:45 AM   #5
Old Coot that's a great looking Chevy .my buddy has a 55 I ate a a great agar B Que place upmuourvway last year in and old gas station.man it was great and the service was unreal. Can't remember the name though. On left goingo into some small town off interstate 85 north of Concord and BPS . Thanks
Old 03-15-2013, 04:34 AM   #6
cpaulsen's Avatar
I use the Dish 1000 with 1 receiver and a splitter....that way I use 2 tv's with one receiver. I use a tripod and have to little line levels siliconed to the tripod. I make sure it is level and usually have a pretty good idea where I need to point the Dish. If any problems I use an IPhone app. No more than about 3 or so minutes to get my picture.
cpaulsen is offline   Reply With Quote
Old 03-15-2013, 07:11 AM   #7
TURBS's Avatar
http://www.forestriverforums.com/for...highlight=dish
These are just a few of MANY toics about your questions regarding satellite tv.
A simple search of dish found these.
Turbs
Old 03-15-2013, 07:18 AM   #8
TURBS's Avatar
With that being said I have dish network at home so I take my spare receiver from my shop an a dish that I got for from an installer removing it and mounted it to a work light tripod.
I can setup level and aim dish with my android phone and sat app in minutes.
Total cost .... free.
As I already pay for the service at home.
Turbs
Old 03-15-2013, 07:24 AM   #9
Turbs
But you never get over 25 miles from home.
Try setting up all over the country where you have to change azimuth, skew & elevation for every new location.
Old 03-15-2013, 07:39 AM   #10
TURBS's Avatar
I've had to redo azimuth and skew plenty my friend.
I change it before I even leave so when I get there.
Setup tripod
Level
Aim
Watch tv
Ps I installed my first satellite dish in 1995-ish.
And my parents had one of those 16' "dishes" back in the 80's
Old 03-15-2013, 08:16 AM   #11
I used to have the same problem. Took me forever. You're missing the essential tool: signal meter. I bought the Triplett version from Amazon.
The problem is that the receiver itself is too slow to respond to a new signal. With that meter, you can do it almost instantly. (I also have the DP AR app for iPhone which gets me started.) I seldom need to change elevation or skew. With the meter, I can usually do that just by changing the level of the tripod legs.
Old 03-15-2013, 08:22 AM   #12
TURBS's Avatar
Correct
Old 03-15-2013, 08:43 AM   #13
Good stuff thanks
Old 03-15-2013, 09:31 AM   #14
Poppy94's Avatar
i just put my dish receiver in the TH, plug into the factory entertainment center system, connect my winegard carryout, hit a switch and a couple of buttons, and BAM......tv on demand. <10 mins. .
makes momma happy to watch the Texas Rangers and Fox News when out and about. low maintenance and easy set up! double bonus for me.
Poppy94 is offline   Reply With Quote
Old 03-15-2013, 09:35 AM   #15
cpaulsen's Avatar
Forgot to mention.....my dish was free....came from a cable company who installed cable to a house and the owner wanted the dish gone.
Old 03-15-2013, 11:46 PM   #16
DougP47's Avatar
Here is a pic of my satellite mounted.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
Old 03-16-2013, 01:36 AM   #17
Indy Steve's Avatar
Setup tripod
Level
Aim
Watch tv
16' dish, my parents had it also...how I miss the non-scrambled, free channels available then as a teenager.
Indy Steve is offline   Reply With Quote
Old 03-16-2013, 03:23 AM   #18
Doug P47, how do you get a signal if the dish is mouned to our roof and you are parked under some trees ? Thanks
Old 03-16-2013, 07:22 AM   #19
Directv
Went to camping world and had them install a covered dish on the roof that works in all kinds of weather and you don't have to go up on the roof with the broom to remove the snow. Were hooked to the the to recievers from the house and still using the progaming from the house. Hated going to campgrounds and hoping their cable systems worked or not.
grizz427 is offline   Reply With Quote
Old 03-16-2013, 08:13 AM   #20
TURBS's Avatar
He doesn't prolly get a good signal parked under tree's.
Good reason not to have it mounted I guess.
Turbs
