Old 05-28-2012, 09:47 AM   #1
TV hookup
I have a 2011 F.R. Salem and I am trying to figure out the television hookup. It came with a flat screen that is plugged in and has a coax to the antenna/booster. The trailer has a cable hookup outside, I am assuming that when you plug in the cable at a park it over rides the antenna? My 2003 Sandpiper had two coax jacks, one for antenna and one for cable or satellite. I just had to move the coax inside from one jack to the other.
It does not appear that I can hookup satellite through this port, so can anyone give me a hint as how to do that?
One last question, next to the antenna connection there are two RC jacks, one red and one white. I thought these were to hook the TV up to the trailers external speakers. So far I can't see how they work for anything. Any information?
PShroyer is offline   Reply With Quote
Old 05-28-2012, 10:12 AM   #2
MtnGuy's Avatar
As far as using the antennae or cable, if you are using the antennae, make sure your booster is on. If you are plugged into a campground cable system, turn your booster off.
Others will have to help with satellite hookups.....I haven't the foggiest.
BTW, welcome to the forum !!!
Old 05-28-2012, 11:31 AM   #3
Thanks Mtnguy...
Appreciate the info.
Old 05-28-2012, 12:20 PM   #4
To switch from Antenna and cable go to the menu on the tv itself. For antenna it will do a scan for channels. when you hook to to cable at sites that have cable the campground should give you a channel guide when you check in.Like others have said when you use the antenna make sure the booster is on and I look at the other trailers in the park and see which way thier antennas are pointed.
imabmwnut is offline   Reply With Quote
