Old 07-26-2013, 12:36 PM   #11
Originally Posted by Stimey View Post
Thanks for the help. Is there any way to bring the sound through the jensen stereo and through the speakers?
Yes you can do this if it's the same Jensen/CD combo I have in my Salem. You'll have to pull the stereo out, on the back/top of the unit you'll see there are 2 RCA audio input's. These are the "AUX" inputs. If your TV has RCA Audio out (the red & white connectors) you should be able to run the wires directly from the TV to the stereo. Plug everything in and mount everything back up. If you only have a digital out (like my stupid TV did) then you'll have to buy a digital to RCA converter box.. they run like $20 on newegg/amazon. Running the audio through the speakers makes a big difference, esp when the A/C is running.
2006 Ford Expedition Eddie Bauer
2013 Salem 26TBUD
nullvalue is offline   Reply With Quote
Old 07-26-2013, 09:12 PM   #12
Sounds good. I will give it a go. Thanks.
Stimey is offline   Reply With Quote
