Old 12-08-2013, 11:17 AM   #1
TV lift failed
Our tv is installed on a lift in the back of our 2011 CC 36RE and recently failed in the down position. There was no warning that there was a problem (such as the sound of a motor failing); it just stopped operating. I've replaced the switch and the 6 amp circuit breaker. There is no controller box; the lift is wired via pigtail to coach power. Can anyone give me some help with respect to repairing this? I've used the volt meter and detected no power coming from the switch to the motor.
Thanks!
GRHooper is offline   Reply With Quote
Old 12-08-2013, 11:40 AM   #2
10x
Sounds like you blew a fuse.
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 12-08-2013, 11:52 AM   #3
litgrep's Avatar
Look for limit switches that stop the travel that may have gotten dirt in them.
litgrep is offline   Reply With Quote
Old 12-08-2013, 12:24 PM   #4
Todouble's Avatar
Originally Posted by GRHooper View Post
Our tv is installed on a lift in the back of our 2011 CC 36RE and recently failed in the down position. There was no warning that there was a problem (such as the sound of a motor failing); it just stopped operating. I've replaced the switch and the 6 amp circuit breaker. There is no controller box; the lift is wired via pigtail to coach power. Can anyone give me some help with respect to repairing this? I've used the volt meter and detected no power coming from the switch to the motor. Thanks!
Check the incoming Side of the switch. If power is there then you have a bad switch!
Todouble is offline   Reply With Quote
led
