Old 07-14-2015, 10:34 AM   #1
TV lift system not working
has anyone had a problem with TV lift not working? I have a 2012 cedar creek 36ckts
Oldblue2 is offline   Reply With Quote
Old 07-14-2015, 01:03 PM   #2
DaveSchwartz's Avatar
Has the spring tension been lost or is it just the release latch that isn't working? On ours, the release cable is connected to a push button on the wall and it takes quite a bit of force to release it. When latched, I can still push down about 1/4 inch but it takes considerable force against the spring.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 07-14-2015, 01:36 PM   #3
dcheatwood's Avatar
My release button was broken on my rockwood fiver. It had broken away from the wall on the backside. I was able to release it from behind the frig one time then never again. Dealer built up the mechanism that holds the release knob to the wall with a metal L-bracket. It was originally held on by brads which pulled loose.
It was hard, and took a lot of effort but I did get it released one time. No problem since repaired. Good luck.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-14-2015, 03:03 PM   #4
This is not a manual type lift. It is a Lippert electric lift that raises the TV from behind the fireplace
Old 07-15-2015, 07:21 AM   #5
dcheatwood's Avatar
Oh. OK. Sorry. Mine is behind the fireplace also but had pneumatic lift. The button only releases it to rise on its own. Hope you get it figured out.
Old 07-22-2015, 02:59 PM   #6
What exactly are the issues that you are seeing? Is the lift system moving at all?
KylePRV is offline   Reply With Quote
