Old 03-10-2016, 08:08 PM   #1
Tv mount
First post, first ?
Just got a 2016 2702WS
It came with a tv mount on the outside.
TV in aide is all bolted in so it does not seem like I can use the inside TV.
How does this work? Should have I recieved another part of the bracket to for a TV
TysonTDW is offline   Reply With Quote
Old 03-10-2016, 08:14 PM   #2
AquaMan's Avatar
Does the outside bracket look like a "V" slot? If so, the inside TV most likely has the same mount. It can be a bit stubborn at times to remove. Try lifting firmly.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 03-10-2016, 08:23 PM   #3
Not the V slot. Two circular slot holes.
Is there not an image in the OP?
Old 03-10-2016, 08:40 PM   #4
Oaklevel's Avatar
Similar to this????
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 03-10-2016, 08:53 PM   #5
Oaklevel's Avatar
Inside mounts on main TV Thought at first it would not come out but found the mount to be as pictured behind the main TV.
ID:	101577   Click image for larger version
1966 Mustang GT
1986 Mustang SVO
Old 03-10-2016, 08:55 PM   #6
Hum, guess you all cant see the pic in the OP. I can see it for some reason
But yes, like that but black. How does it work?
Thanks.
Old 03-10-2016, 08:57 PM   #7
Awesome!!!!! Thanks. I didn't assume the entire arm would come out. I'll look at it again.
First post a success. I.like this forum already!!
Old 03-10-2016, 08:57 PM   #8
Sounds like you have the mount that Forest River gets from:
Ramco Engineering,Inc.
2805 Frederic Drive
Elkhart, IN.
800-321-4819MSCSL12-QD.
Bought one for our bedroom to match the outside bracket and what the main TV is
mounted with.
________________
MK Clark
2819VS Windjammer.
MKClark is offline   Reply With Quote
Old 03-10-2016, 09:01 PM   #9
Oaklevel that is what we got from Ramco.
MK Clark
mount, tv mount
