Old 11-03-2013, 01:01 PM   #1
TV mount
2013 freelander 29qb. Anyone know wher blocking is to mount tv in bedroom? Measurements would be great.
I emailed tech support 2 weeks ago with no response. Am I expecting too much from them?
Panhandler is offline   Reply With Quote
Old 11-03-2013, 01:09 PM   #2
Ford Idaho's Avatar
Is there a coaxial connector on the wall?
Old 11-03-2013, 07:02 PM   #3
Yes ther is as well as a 110v outlet. They are on the wall between the toilet and the bed room.
I don,t want hit wiring when I install the mount. Hopefully there is blocking in the wall I can mount to.
Old 11-03-2013, 07:21 PM   #4
Average Joe
MrJoe's Avatar
Will a stud finder work?
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 11-03-2013, 07:25 PM   #5
TV mount
I can give it a try...
Old 11-03-2013, 07:40 PM   #6
Ford Idaho's Avatar
You are not looking for a stud but what may only be a 6"X 6" piece of plywood behind the wall about where the outlet is.
The plywood may be bigger but not by much.
Old 11-03-2013, 07:53 PM   #7
Backer
In my Sabre 2013 32 RCTS the backer in the bedroom was a metal strip of something called "EGS". Seems they use this stuff as backer for cabinets and other stuff that gets hung. The Palomino tech let me know that the backing in the living area was different. It was wood and not EGS. He was able to send me the attached drawing so you should be able to get one as well. This all happened last week. I used a stud finder in the area and measured not 6 inches (as the drawing states) but 9 inches of backer. A stud finder should do the job. Banging on the wall didn't help at all. You should figure out if it is metal or wood. I was going to use Lag bolts but at the last minute after finding out about the EGS I used metal screws.
Hope this helps somewhat. I also attached the Prime Time brochure. It sort of explains EGS about 3/4 of the way into the document under construction.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 11-10-2013, 09:31 PM   #8
Still looking
I am still looking for the measurements for mounting the tv in the bedroom
mount, tv mount
