Old 06-10-2016, 04:58 PM   #1
TV mount backer (avenger ati 27 dbs)
I have 2017 Primetime Avenger ATI 27dbs. The bedroom has coax cable and outlet for TV. However, there is no TV backer sticker. I was able to locate where the sticker was originally (by going back to dealership and looking at same model), but it does not feel solid behind it (I don't feel a stud at all). I'm curious what type of TV backer is behind there. If it is metal, then I should be using metal self tapping screws. Or, is it just wood screw? And, how much weight will it hold? Why is this not in owner's manual!
tshep_dog is offline   Reply With Quote
Old 06-16-2016, 02:06 PM   #2
Mounting
I figured it out, and thought I would just reply to my original post in case someone reads this in future.
First, I needed to understand if there was a metal plate behind the wall. I purchased some strong magnets at HD and found out there is not. So, I assumed wood studs would be there.
I drilled a small pilot hole (with smallest drill bit) into the spot that I wanted to mount the TV. There was not resistance and I didn't hit anything (be sure the drill bit is short so you don't drill through the wall on the other side). I dropped 2 inches lower and tried again but this time I drilled into solid wood. I used 2 lags screws (I had to purchase a shorter version at HD) mounted the TV as instructed.
Old 10-30-2016, 02:56 PM   #3
27DBS TV Size for Bedroom
We just bought a FR Avenger 27DBS. It has a cable connection and TV mounting site on the wall in the bedroom. Does anyone know what size TV can fit in that location, next to the door?
sbgreenbaum is offline   Reply With Quote
mount, tv mount
