Old 07-22-2014, 10:34 PM   #1
tv mounting
I have a 2014 sunseeker 3010ds. I want to access the inside of the cabinet the tv is attached to in the kitchen area. after removing the tv i see no screws to get inside the cabinet. I am guessing somehow it can be opened as there are several wires running into it and also some antenna connections mounted to the side.
Can anyone help.
thanks
chucknviv is offline   Reply With Quote
Old 08-03-2014, 08:57 AM   #2
Wish I could answer your question but instead I'm going to ask you one. I have the 2013 Model and I can't figure out how to get the tv off the mount. My power cable came out of the port on the back of the tv and I can't get my fingers into the tiny space to re-attach. How did you get that thing off the mount?
bafarr is offline   Reply With Quote
Old 08-12-2014, 11:01 AM   #3
Tv
On my tv you lift straight up about an inch and it comes straight out. Some have said there is a lever or catch behind the tv but mine does not. Hope this may help
Old 08-15-2014, 06:19 PM   #4
Thanks! I'll give it a shot and let you know. Just pulled in for the weekend so I'll have some time.
Old 08-24-2014, 05:00 PM   #5
Nope. No luck there. Will continue to research. Thanks anyway.
mount, tv mount
