Old 12-07-2018, 09:04 PM   #1
TV Mounting bracket
I recently bought a used flagstaff 8289ikws. The TV had been taken out but the bracket is still on the wall. Can anyone tell me where I can find the replacement parts that will attach a tv to the existing bracket.
ID:	192797   Click image for larger version
Golfingal is offline   Reply With Quote
Old 12-08-2018, 05:48 PM   #2
CincyGus's Avatar
I've never seen that bracket before but have seen some similar in RV's. If you give up finding the male to your female half, check out monoprice.com for new and relatively inexpensive mounting brackets.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 12-08-2018, 06:22 PM   #3
Our 2017 Blue Ridge tv uses the same bracket should be a common item from an RV dealer.
Okie Dokie 2 is offline   Reply With Quote
Old 12-08-2018, 06:28 PM   #4
Contact Ramco Engineering.
https://shop.ramco-eng.com/collections/flush-mounts
2rad4u is offline   Reply With Quote
mount, tv mount
