Old 06-04-2015, 09:50 PM   #1
tv problems
just purshased a new 26rr.. I hooked new tv up and did channel scan.... worked great .... tried to hook up another new tv in bedroom ... hooked RCA cable connector to tv and power cord... did scan got nothing no channels,we are using roof antenna only????? please help thanks in advance
champions is offline   Reply With Quote
Old 06-04-2015, 10:00 PM   #2
Just a member
kandl's Avatar
RCA connector or coax connector? Some coax cables supplies with some TVs have issues right out of the box.
Btw, welcome to the forum.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge 1500 (the Beast)
kandl is offline   Reply With Quote
Old 06-05-2015, 12:59 PM   #3
Cuzdog's Avatar
See my post on Cable Connection Exterior. I would check behind the booster plate for a splitter, may have a connection issue. What i found is, the outside cable and antenna cables come to the booster and then split off from that point. If you plan to use the outside connection for cable or sat it best to get it away from the booster.
Cuzdog is offline   Reply With Quote
Old 06-05-2015, 04:39 PM   #4
gooiebob's Avatar
Ours wasn't connected at the plate in the bedroom. It was just folded over in the wall.
2019 Della Terra 29k2s
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
