Old 06-11-2014, 07:48 PM   #1
TV reception with JACK HD antenna
Purchased the JACK and it really does bring in the channels with a crystal clear reception. When I connect the antenna to the exterior connector on the trailer, the TV detects very few channels and the signals are weak (many non-viewable). In contrast, when I hook the antenna directly to the back of the TV, 20+ channels are found and all are strong and crystal clear.
Is the signal strength lost via the external connector because of all the splitters and distance travelled before reaching the TV?
Is there a way to get the strong signal strength to the TV via the outside connector?
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 06-11-2014, 09:59 PM   #2
Evereddie's Avatar
I don't know your trailer but are there 2 connectors on the outside where you are hooking it into? How are they marked?
Evereddie is offline   Reply With Quote
Old 06-11-2014, 10:10 PM   #3
There is no marking on the connectors. There is a single connector with a rubber cap. This one is beside an outlet where you lift the flap. There are 2 connectors inside this outlet. I just assumed the single was an "in" and the 2 inside the box were "out".
Old 06-11-2014, 10:19 PM   #4
The 2 under the flap should be marked Cable and Satellite. The single is a telephone jack????
Old 06-11-2014, 10:21 PM   #5
Evereddie's Avatar
The single connector with the rubber cap is an OUT. It should come off of the antenna if the antenna is hooked in like it comes from the factory. (there is at least a two way splitter in that antenna system) The 2 connectors under the door are both in's. One of them should go directly to a connection around your TV panel. In most it is marked cable on the outside. Try using that one.
Old 06-11-2014, 10:30 PM   #6
Evereddie's Avatar
Why can't you bring the signal from the new antenna in on the original cable that was on the roof for an antenna?
Old 06-12-2014, 06:59 AM   #7
Ddubya's Avatar
It could be a bad cable connection, bad cable, or the antenna amplifier switch in the wrong position
2017 Alpine 3401RS,Titan Disc,Morryde SRE 4000, 2016 Ram 3500HD Laramie SRW,LWB,4X4, Aisin transmission
Ddubya is offline   Reply With Quote
Old 06-12-2014, 07:52 AM   #8
Herk7769's Avatar
Still confused about the "Jack" using the satellite/cable connection on the outside. There is no way to get power to the Jack to even work...
Name:	CBL and SAT inputs.jpg
ID:	55037   Click image for larger version
Name:	Winegard wall plate rear.JPG
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-12-2014, 07:54 AM   #9
I'll give this a try next time out. (Strange there are 2 "ins"?). Yes, I could go to the roof. The idea was to place the antenna (made a stand for it) on the truck bed and just connect it to the trailer. The factory antenna is fine for certain locations and I wanted to leave this as is.
Old 06-12-2014, 07:55 AM   #10
I hook the JACK to my spare 12V battery in the truck bed.
Old 06-12-2014, 08:16 AM   #11
Herk7769's Avatar
OK, then try this:
Use the "IN" Marked "SAT" and connect your TV to the SAT/AUX marked wall plate connection.
You "might" be able to use the one marked CABLE, by turning off the wall plate (no light on) and then you can use the distribution network off of the TV/TV2 output of the wall plate.
Remember you will still need to scan for TV channels every time you re-orient the Jack antenna.
Old 06-12-2014, 08:23 AM   #12
OK, then try this:
Ok, that makes sense. We won't be out with the trailer till the beginning of August. I'll give all these suggestions a try. THX!
Old 06-12-2014, 09:29 AM   #13
Evereddie's Avatar
I was thinking about that also but when he said he hooked the Jack directly to the TV and got all those channels I figured he had a power injector inline already.
I still think replacing the old antenna on the roof with the Jack and be done with it is the way to go.
But after reading his last post I think there is a much bigger problem. Having to wait all the way until the first of August to go out in the camper is a crime!
Old 06-12-2014, 11:45 AM   #14
Good one! Not retired yet. We do get between 4-5 weeks of trailer time each year. We have about 2 weeks left this year.
Old 06-12-2014, 12:08 PM   #15
Evereddie's Avatar
Well that's plenty of time. We are not retired yet either but take every other weekend off, sometimes 3 day weekends, and find something within a few hours drive time. We are blessed with a lot of options where we live in North Carolina.
Old 06-12-2014, 02:11 PM   #16
Make sure all the connectons going into the wall jacks are good. Have a 2014 Rockwood 2104S and all the connections in the wall jacks had come loose. I couldn't get but three channels, and after checking the connections behind the panels I was getting 30. Same thing happend to my power button for my awning, the wire came loose from the spade.
GAC2460 is offline   Reply With Quote
antenna, reception, tv reception
