Old 03-24-2016, 08:34 PM   #1
TV signal out on the patio
My MBS didn’t have an external entertainment center (i.e., TV) as an option, so I’d like to get a “portable” TV working out there on the patio. The 2016 2401S does have what appears to be a coax port on the awning side just aft of the entry door (see picture).
I thought I could just use a coax cable to connect that port to my Samsung TV. I had the over-the-air antenna booster on with good signal from a local channel showing on the LR TV. But I got nothing on the Samsung even though I cycled thru every channel on the TV (162 of them!).
Does anyone know what controls signal to this port, and what special I need to do to connect a TV to it?
John& Sherry
2016 2401S, towing 2013 Mini Cooper
Colorado Front Range
the1murphman is offline   Reply With Quote
Old 03-24-2016, 08:49 PM   #2
Left Coast
Do a channel scan from the tv's menu
Old 03-24-2016, 08:50 PM   #3
rracer5's Avatar
Could that be your "park cable IN" port?
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 03-24-2016, 11:24 PM   #4
@Bob: yea, channel scan works great. Used it in multiple locations last trip. The over-the-air signal was great. Cable lower quality ... go figure?
@rracer5: I guess that is part of the question. The outside of the RV has two coax port. One on the passenger slide, like I posted. And another on the driver side just forward of the shore electric connection point (see picture). No distinguishable markings on either to know what's in or out???
John& Sherry
Old 03-25-2016, 07:04 AM   #5
Left Coast
If you happen. to have a 50' coax, connect to outside port and take the other end inside along with an ohm meter and check inside connections ....using the free end as a jumper.
Old 03-26-2016, 11:13 AM   #6
The1murphman, your post regarding the over the air signal being great and the cable signal a little worse is very much true. Over the air signals are true digital. When you get a good signal you get a great tv picture, however for cable the signal while digital is compressed, boosted, reduced etc to send it thru the lines and it is not always digital quality. If you need to use a digital converter box, most don't now days, this is taking a digital cable signal and converting it to analog.
Rich5117 is offline   Reply With Quote
Old 03-26-2016, 11:31 AM   #7
Left Coast
Have you checked the coax connections for being snug?....No pic difference here....after pulling all plates and snugg'n them all up
Old 03-26-2016, 03:04 PM   #8
Sorry, but it is true over the air digital is HD quality. Cable companies don't broadcast in HD unless you pay an upgraded fee and use an HD box. Most campgrounds that send a signal to a post is just SD and is probably not HD quality
