Old 09-20-2016, 01:08 PM   #1
TV sound through Entertainment system
Has anyone managed to accomplish getting TV sound to come thru their entertainment system speakers?
Georgetown 378TS
Mike and Linda
2011 Georgetown 378TS
2011 Honda CR-V
Journey14 is offline   Reply With Quote
Old 09-20-2016, 01:38 PM   #2
Yes
2016 Flagstaff 23lb
Toddupton is online now   Reply With Quote
Old 09-20-2016, 01:46 PM   #3
RSchleder's Avatar
Turn your TV & sound system on. Keep pushing the "MODE" until you see "TV Sound" on the screen readout. You should now have sound thru your sound system. Be sure to turn off your outside speakers ( mine are button #3) or you'll be blasting the TV sound outside and your neighbors may not be watching the same program your watching. On my system, you MUST have some level of sound coming out of your TV speakers as your sound system is amplifying your TV sound. No sound out of TV, no sound out of your sound system. You can play with the sound levels on both to get the sound to where you like how it sounds.
Days camping (2016)----181 days
Days camping (2017) --- 14 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 09-20-2016, 07:44 PM   #4
Thanks so much, but that does not accomplish it. I have "source" then "aux 1" and "aux 2". The rest are your usual "fm," "DVDs" etc.. No "TV"
Thanks again.
Mike and Linda
2011 Honda CR-V
Old 09-20-2016, 07:50 PM   #5
Smile Tv sound
Mine is aux 2. Sometimes I have to turn the sound system off and on again after I select aux 2
Alleyantique is offline   Reply With Quote
Old 09-20-2016, 07:55 PM   #6
Georgia Frog Rally 2017
aceinspp's Avatar
Originally Posted by Toddupton View Post
Yes
Yep no problem. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
aceinspp is online now   Reply With Quote
Old 09-20-2016, 07:55 PM   #7
What brand entertainment system do you have in your Georgetown?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-22-2016, 09:25 AM   #8
AMG
In the stealth, someone in that forum told me that he had to run a 3.5mm mini stereo cable from the headphone output on the rear of the TV, back to the stereo headunit input. After that it would have TV sound through speakers. Not sure if that applies to yours.
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
Old 09-22-2016, 10:38 AM   #9
Thanks. I believe I have figured it out. Georgetown did not run an "audio out" cable from TV to the theater system. As it is all wired behind wall, I have to externally run a RCA cable between them..... Unless I can find a 4 point audio cable extension (2 audio in and 2 audio out ) to run off the internal audio cable .
Thanks again.
Mike and Linda
2011 Honda CR-V
Old 09-22-2016, 11:04 AM   #10
AMG
Thanks again.
Stealth once again... it is behind the wall and the guy who did it on his 2016 said it was easily fishable through the wall. not difficult like expecting to do it in a home without some drilling in firewall studs, etc.
entertainment
