Old 05-04-2014, 06:58 PM   #1
TBT
TV Trips GFCI
Hello, I purchased a 2013 WorknPlay Toyhuler that came equipped with a 32 flat screen KONICA LCD TV. ( never heard of this manufacturer) the TV is on the GFCI circuit and trips the GFCI breaker every time I plug it in. When the TV is unplugged the circuit breaker does not trip. Anyone have any ideas as to what might be the issue?
Ted-n-Marlene
2008 Ford F250 6.4 TD
2008 22' Pathfinder Bay Boat
2009 HD FLHX Streetglide
2013 Work&Play 25 UDT
TBT is offline   Reply With Quote
Old 05-04-2014, 07:02 PM   #2
When you plug in another appliance .....it works ok...doesn't trip?
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 05-04-2014, 07:17 PM   #3
TBT
I have plugged in the coffee pot with no problem..I have also plugged in the TV with an extension cord to the bedroom outlet and have had no issue with tripping breakers. I think it is has something to do with the electronics in the TV that the GFCI is sensitve too, just looking for other ideas..
Ted-n-Marlene
Old 05-04-2014, 07:58 PM   #4
Has the tv worked in the past? Did it happen to get damp or wet? Does the power cord pull out on tv or is it hardwired? What is the watt draw for the tv?
Jerry. Vietnam vet.
Retired
Old 05-04-2014, 08:17 PM   #5
Phat Phrog Stunt Crew
elind's Avatar
The circuit breaker kicks out when too many amps are being used on a circuit. But the GFCI trips when power feeds into to a ground wire for a split second. I would say there's something going on with the TV electronics.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 05-04-2014, 08:31 PM   #6
fast murray's Avatar
Maybe take the cord off the TV and see if the cord alone trips. It's possible that the cord is bad. That would be an easy fix.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 05-05-2014, 05:58 AM   #7
TBT
Thank you very much for the troubleshooting tips.. I will check the TV cord first and if that doesn't fix it I will try plugging in another similar size TV to eliminate the cause..
Ted-n-Marlene
Old 05-05-2014, 02:39 PM   #8
BandJCarm's Avatar
Hmmm.
My GFCI circuit is on the entry door side of the Camper. That area has several double elec plugs. If I plug ANY two things into ANY of them, the GFCI trips! It'll handle most things that are plugged in, so long as they're alone. The outside plug in is in this loop also. Same results.
Beats me why. I don't know why they can't make higher amp circuit breakers for each circuit.
BandJCarm is offline   Reply With Quote
Old 05-05-2014, 03:01 PM   #9
Master electrician here, I agree problem is in the TV or the cord to the TV. It only takes 4 miliamps of lost to trip it out.
I would replace the TV and be done with the issue.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-05-2014, 04:58 PM   #10
How about we just get rid if the GFI outlet?
cadman99 is offline   Reply With Quote
