12-26-2015, 10:45 PM
Tv troubles
Hey guys, the last time we took our TH out when hooked up the tv would not pick up cable. I bought a brand new cable to make the outside connection and the tv is fairly new also. The tv picked up your typical static local channels but not cable. Could the interior cable have gone bad? If so what's the easiest way to change it, I was thinking of disconnecting inside and outside and tying one end to the new cable and pulling it through? Has anyone had this problem before and how did you fix it?
Sent from my iPad using Forest River
2014 Dodge Ram 2500 Mega Cab 4x4 Diesel
2010 Sandstorm 203SLC
12-26-2015, 10:59 PM
since it picked up the local over-the-air stations, sounds like you didn't turn off the antenna booster button.
it has to be off to be able to detect cable stations.
pretty common mistake that many make.
once it's off, go to the tv's menu and have it do a cable channel search, not the air search.
12-27-2015, 02:17 AM
There is also a chance that you plugged the outside cable hookup into the AUX or SAT input instead of the cable input. BTDT.
If you were seeing TV channels with static you were most likely seeing a week form of the cable signal leaking in. Over the air channels are almost all digital which is either there or not. Very little in-between with digital. On a cable system it is more likely there are analog channels mixed in with digital too.
12-27-2015, 09:00 PM
Where is the antena booster button. We had the same problem I tried connecting cable cord directly into cable connection on wall next to tv and cable would not work. Took another TV to use instead and sound is bad on TV.
Nancy
12-27-2015, 10:47 PM
Nancy
In my TT it's located to the TV connections. Look for a tiny button that will be green when the booster is on. Here's a picture of what mine looks like.
Remember to do a scan for cable channels.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
12-28-2015, 09:19 AM
Thank you for your input. We will try that.
Nancy
12-28-2015, 09:44 AM
Left Coast
Did that fix it?
12-28-2015, 10:00 AM
Have not tried it yet. Taking it out of storage on Tuesday to do some work on it before travel.
Nancy
12-28-2015, 10:01 AM
Left Coast
Ok....let us know....
12-30-2015, 06:12 PM
Thanks for the info guys! This is our first camper and we are still learning the ropes, the camper is covered and parked at home for now but will check this on the next trip!
01-06-2016, 09:06 PM
Tv troubles
Attachment 96862
Attachment 96863
According to your picture, you get 323 digital channels and 65 analog?? How is that?
Somedays I wake up Grumpy, somedays I just let her sleep......(Ray Scott)
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
01-06-2016, 09:17 PM
Some cable systems have that many channels. Sometimes dozens and dozens that are just music channels. Some cable systems have dozens of dedicated sports channels. Most of which have nothing on them most of the time.
01-06-2016, 09:35 PM
Tv troubles
Thanks for the reply. I thought that was coming off your antenna. If it was, I wanted one. Cheers!🍻
01-06-2016, 11:30 PM
This campground offered cable service at the time the picture was taken. I would get a lot of channels but many shows would repeat. Example: channel 61.1, 61.2, 61.3, etc. would be the same show.
