Old 07-07-2015, 03:16 PM   #1
Unhappy Unable to turn TV volume up
My Jensen TV's sound is difficult to hear even when turned up to the max volume of 100. Does this have to do with the fact that it is a 12V/110V rather than a straight 110V? I have the same problem with the TV in my trailer. In order to hear the sound, I have to plug in my BOSE mini speaker and turn off the TV's speaker. Anyone have the same problem?
susanjebbia is offline   Reply With Quote
Old 07-07-2015, 04:32 PM   #2
RV Vagabond Jerry
Jerry Dixon's Avatar
Sounds like a personal problem - take it to a repair shop
Jerry Dixon is offline   Reply With Quote
Old 07-07-2015, 04:43 PM   #3
Don't know if this applies to your RV set up? I have Jensen radio/DVD player and TV in my TT. When Air Cond is running, the TV volume doesn't suit, so, I run a connector from the TV headphone output to the radio/DVD Aux input. I then get TV sound through the ceiling speakers.
martinto is offline   Reply With Quote
Old 07-08-2015, 09:02 AM   #4
Personal problem? Please refrain from responding to threads in which you know nothing. Replies should only come from those who have experience with the situations to which he or she replies. Your reply was of no use.
Old 07-08-2015, 09:27 AM   #5
Jim Schings's Avatar
Sounds like I may have a personal problem also. . I have 3 sets in my RV (w/the outside one) and sound level is barely adequate. (Mine are 110V only) I think this is getting to be typical with newer TV audio output since most people (in the home) use aftermarket audio system amps. In the home mine would be ok, but with a gen working etc......
Jim Schings is offline   Reply With Quote
Old 07-08-2015, 09:33 AM   #6
Boss Ox & Drovergirl
oxcamper's Avatar
Yep. A/C really drowns out the sound from the TV.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 07-08-2015, 09:42 AM   #7
When I return home from my vacation, I will install a permanent aftermarket sound system to boost the sound.
Old 07-08-2015, 10:21 AM   #8
Left Coast
Also depends on where speakers in tv are mounted and their size. Some are on back, some on bottom, few on front...might be able to Google your tv to find out.
Old 07-08-2015, 12:17 PM   #9
If you have the Jenson dvd set up like mine, I would check for rca jacks to connect to it. The red and white rca jack should go to output of back of tv to the Jenson dyd system. Then use the volume control on the dvd stereo system, because at that point the tv volume on mine does not help anymore.
Rolltide is offline   Reply With Quote
Old 07-08-2015, 03:12 PM   #10
KAS
I have the same problem with my 12V Jensen TV when the A/C is on. I noticed it also depends on the channel (air), maybe cable is better.
KAS is offline   Reply With Quote
