Old 10-11-2016, 04:50 PM   #21
Originally Posted by 67hvymtl View Post
I thank you all for giving me the reassurance to take on the task
My next question is this:
My tstat has a fan only setting as well as the heat and cool setting on the left just like this picture. Is this tstat still going to work?
RVP 8330 3862 Coleman Mach Black Digital Wall Thermostat RV camper Trailer | eBay
I have this tstat and when I have the air on or just the fan on, the fan lo/hi switch doesn't change the fan speed . its always runs on hi. Does anyone else have this issue or am I doing something wrong
2015 Flagstaff 27RLWS
2014 Ram 2500 4x4
LindaNTom is offline   Reply With Quote
Old 10-11-2016, 10:34 PM   #22
Witch Doctor's Avatar
Change your setting to AUTO LOW, You should be okay, not much difference between high and low, if you put it to ON the fan will stay on 24/7 ... Also make sure you didn't use the high speed wire connected to the low speed terminal on the stat.... PS: NOW LETS PLAY BALL, CUBBIE YEAR.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
thermostat
