Old 06-29-2014, 06:21 PM   #1
Using Genesis GT 3.0 TV speakers buzz, why?
I have a 2015 Flagstaff 5th wheeler with Genesis GT 3.0 system. The dealer hooked everything up and everything works. The only thing I have a problem with is the speakers buzz when we watch TV, either cable, antenna or satellite. Can anyone help? The V volume is set on AUX 2.
Thank-you,
Jeni
jbrizard is offline   Reply With Quote
Old 06-29-2014, 07:02 PM   #2
Herk7769's Avatar
This can be your LED lighting if you have that. Turn them ALL off to see if the buzzing stops.
Ground Loops - Low Hum, Buzz from speakers or headphones - Turtle Beach :: Knowledgebase
Try a ground loop isolator if not located in the LEDs.
Ground Loop Isolator : Isolators | RadioShack.com
HAM CALLSIGN - KC3FFW
Old 06-29-2014, 08:26 PM   #3
Thank-you, I'll give it a try. It was not the LED lights.
Old 06-29-2014, 09:23 PM   #4
QCCowboy's Avatar
Herk is spot on. Most buzzing coming through a 12 volt audio system is typically the cause of a grounding issue. Does it also buzz on radio or CD/DVD? If so, perhaps try to find a better ground for the stereo or as he mentioned add an isolater.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 07-06-2014, 12:46 PM   #5
Thank-you all! I used the isolator and it worked!!!
Old 07-25-2014, 02:39 PM   #6
Genesis GT 3.0 issue need help!
I just had my radio changed out by Forest River in December 2013.
Just found out that the radio and DVD sound only comes out the center and rear speakers until the unit heats up and then 5.1 starts to work. When the a speaker are off and B is on you can hear the A speakers in front start to crackle. I think there is a cold solder issue.
All the wiring is checked and was correct.
Has anyone else had this issue?
Should I try FR to see if they will replace this unit?
Thanks in advance.
jjjammer is offline   Reply With Quote
