Old 01-26-2016, 12:38 PM   #1
Pauls Toy Hauler's Avatar
Using Heater/Furnace while Boondocking or no Shore power
I have a 2015 351-THSS from Palomino. My thermostat on the wall controls the A/C, Heat & Fan modes. In my previous TT it had a thermostat that only controlled the furnace because my A/C was just the ceiling type with controls directly on it.
My question - I tried running the heater off shore power but the thermostat did not come on. Does my furnace not run on 12v/battery power? How do folks use the furnace while boondocking?
Thanks in advance
Paul
2015 Palomino Puma Unleashed 351-THSS 37' Toyhauler
2016 F-350 Platinum DRW 4x4 w/ Curt Q24 hitch and Air Lift rear air ride
"Just put that hammer down and give it hell" -Jerry Reed
Pauls Toy Hauler is offline   Reply With Quote
Old 01-26-2016, 02:26 PM   #2
Head Rambler
Assuming you mean that you tried to run it when not on shore power. Your furnace should run as long as the battery is charged and is connected to the RV electrical system.
Will it run when you're on shore power?
Have you checked the fuses in the converter/power panel?
Gotta go campin!
Old 01-26-2016, 04:44 PM   #3
bikendan's Avatar
The furnace runs ONLY on 12v battery power.
Shore power only keeps the batteries recharged.
If you plan on doing this often, you need a two battery setup at minimum.
The furnace is the biggest battery power consumer in your trailer.
It can drain a single battery in one night.
When you turn the thermostat to Heat, there's usually a delay.
Is the battery installed or is there a battery disconnect switch?
Equalizer WDH
Old 02-04-2016, 11:51 AM   #4
My scenario was we were needing to leave for a couple hours where I couldn't take the 5th wheel but wanted to be completely unhooked from the shore power so when I got back I just hook up the trailer and leave. I needed to keep it on for my two dogs and it was about 38 degrees outside. I disconnected the shore power to test it out and went to my dometic thermostat and tried to select to furnace but it wouldn't turn on. as soon as I plug it back in then I can to thremostate and switch to furnace. So I understand or at least have the notion that the furnace runs on the 12v, but I can't get it to turn on. I think I'll need to play with it more.
Old 02-04-2016, 11:57 AM   #5
fonzie's Avatar
When you disconnected from shore power, did your 12 volts lights still working? do you have a battery disconnect switch?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 02-04-2016, 12:07 PM   #6
Yep. they were still working. all 12v functionality was available. I do have a battery disconnect but I hadn't disconnected it right at that moment because I was testing if this was going to work. I just know there has to be a way to run it.
Old 02-04-2016, 12:38 PM   #7
Head Rambler
What is the voltage of your battery when it's disconnected from shore power?
Gotta go campin!
Old 02-04-2016, 02:03 PM   #8
Good question. Not sure. I need to install some type of meter.
Old 02-06-2016, 10:28 PM   #9
MNtraveler's Avatar
Yeah, at least get a multimeter. You need it! The fan should come on first, flowed by heat. The heat won't come on until the fan comes on and circulation is confirmed. Do you have fan?
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 02-07-2016, 08:14 PM   #10
SeaDog's Avatar
The furnace in your RV is no different than the furnace in your house except it runs on 12V. The sequence of events is. select heat at the stat, In a short time you should hear the inducer fan start followed a short time later by the burner and then the main blower fan. I would suspect your batteries are dead if it will run with shore power plugged in and not when unhooked.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
furnace, heater, power
