Does anyone have a 268RKS and can tell me if your LR TV cable outlet is above the shelf where the TV would hang, or if it is down under the shelf in the cabinet? On our is it inside the cabinet and we will need to drop the cords down thru the shelf to plug them in. Doesn't sound right to me.
Mike and Susan
Cavalier King Charles - Jack (4) and Sadie (3)
2015 Columbus 320 RS
2017 Ram 3500 6.7 Diesel
Mine is in the cabinet as well. Ours came with a TV and the cables were already run through. The TV sits low enough to the counter top that it doesn't look bad to me.
2015 268RKS Vibe Xtreme Lite
2012 F-150 EcoSCREW Max Tow
Ok, thanks. I found that odd, but for some reason a TV was not part of the options. I got a bracket and TV easy enough, but wanted to make sure they weren't blowin wind up my skirt. We pick it up tomorrow!
Mike and Susan
Anyone have a quick and dirty description on hooking up a sat dish to the vibe 268RKS? Not sure which outdoor coax connector is which they ar not marked well. One above the other with a label cable/sat. I assume the unused coax connector under the tv would be the sat but no directions provided. Any advice is welcome.
