Old 06-29-2010, 07:29 AM   #1
yvesm's Avatar
Vibration from roof top AC
We got to use our AC unit (Dometic 15K btu) last weekend. When we ran the fan on high the roof started to vibrate the noise was so loud that you could not talk without raising your voice. It appears that the fan is out of balance or the shaft is bent, anyone else run across this problem. The unit is a 2011 Rockwood 2902SS.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 06-29-2010, 08:49 AM   #2
Don't have the problem, but you should be under warranty. I would take it in.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-29-2010, 09:30 AM   #3
tmmar's Avatar
Another thing you could look at are the hold down bolts. You should see if they are snug. Take the inside cover off and you will see 4 bolts -one in each corner. They should be snug- not overly tight. May help the problem.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-29-2010, 11:33 AM   #4
Just installed a second Dometic unit on our coach last weekend, brand new out of the box and the blower motor was not installed correctly allowing the cage to touch the side of the housing. We had to take the cover off, then the cover for the motor to adjust the support for the motor. Once we had that done, sounds and cools great! I bet that support piece has moved around on yours too, it's only held in place with two screws.
Chasracer is offline   Reply With Quote
Old 06-29-2010, 12:26 PM   #5
yvesm's Avatar
I took a look at the fans and they wobble quite a bit, look like the motor shaft is bent, one more thing to deal with . We are leaving for 10 weeks next week......what are the odds that my dealer can fit me in . I have spent the last 6 weeks fixing various items thru the camper, but this takes the cake!
Old 06-29-2010, 03:43 PM   #6
Another thing to check is on the fan itself, make sure a mud dobber didnt build a nest on one of the blades, It happened on my last 5th wheel, sounded like the fan was coming apart and vibrating the entire rig
bad1032 is offline   Reply With Quote
Old 07-08-2010, 06:40 AM   #7
yvesm's Avatar
Went up on the roof last night and took a look at the external fan and there is was, a mud dauber nest! Cleaned it out and the vibration is gone.
Old 07-19-2010, 12:49 AM   #8
Iggy's Avatar
bad1032 gets 5000 extra points for finding the solution. WOW!
Yvesm,
Now you can go on vacation for 10 weeks.
Have a great trip and try and keep in touch.
Old 07-27-2010, 12:23 PM   #9
NWC72's Avatar
BAD1032--Thank you thank you thank you!! We also had a vibrating rumble in our AC. Inside looked fine. Son pulled the cover outside and wow! Full of dauber nests. Cleaned them off, and now it purrs like a kitten. Thanks for the tip!!
2005 Rockwood 8280ss
2003 GMC 1500 Extended Cab "Dwight" (sold)
2005 Dodge Ram 2500HD QC4x4 Cummins "Brutus"
Drawtite Brake Controller
16K Pullrite Superglide
NWC72 is offline   Reply With Quote
Old 07-27-2010, 06:10 PM   #10
jimh's Avatar
dirt dobbers
that's quiet common along the gulf coast. i had also had them build on the inside squirel cadge blower. now that u know u are around them, if u haven't instlled a screen over the heater vents(outside), u should do so. that will be the next problem area and it isn't as easy to remedy.
jimh is offline   Reply With Quote
