Old 03-13-2019, 07:34 PM   #1
Victron Monitor Alternative
May be worth looking into.
AiLi Battery Monitor
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 03-13-2019, 07:50 PM   #2
there was a review on youtube on that exact model xantrax makes a couple of models as well not cheap but rather alternatives the xantrax link and xantrax pro link any one with any knowledge on either of those with a comparison to the victron bm-712 would be nice
cl733 is offline   Reply With Quote
Old 03-13-2019, 08:50 PM   #3
It certainly looks like it would be an improvement over the standard Christmas Tree monitor that is standard equipment on a new trailer.
If you are looking for a monitor that uses a more complex algorithm to determine when you've reached 100% charge after a deep discharge and any of the other 60+ capabilities of a Victron 712, this one will NOT be the one.
It most likely just tracks current out over time (ah) and while charging adds back it indicate state of charge. How complex would you expect for $33 versus $200+
Also, one should ask themselves what else they will be adding to their 12 v system in the future. I'm glad I went the Victron monitor route as I later added a Victron Smart MPPT controller to go with my solar panels. The monitor and solar controller work together to share voltage and battery temperature (which allows the solar controller to adapt charge rate to the temp.). If that's your goal it's good to look at items that can be integrated into a system and work well together.
Yes, often those items will cost more but it can be really nice to have an alarm that goes off at a given state of charge, over voltage, under voltage, high temp, etc, etc, etc.
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
TitanMike is offline   Reply With Quote
