Old 02-16-2019, 12:01 PM   #1
Vizio TV back panel access - 2014 Xlr thunderbolt 395amp
I need to access the TV wiring connections (HDMI etc) on my Vizio mounted above the living room door. It appears that the wood trim is literally built around the TV. There are two screws above and two below the TV but several other pieces of wood trim are on the sides and bottom. It appears that the trim may even be glued on. I'm afraid that if I take it apart, it may not go back together well.
Has anyone removed this TV and can offer any advice on how to do this? I'm hoping there's some"trick" to accessing the wiring on the TV that I just haven't figured out.
ID:	196939   Click image for larger version
ID:	196940   Click image for larger version
ID:	196941   Click image for larger version
ID:	196942   Click image for larger version
RingMaster is offline   Reply With Quote
Old 02-27-2019, 11:50 AM   #2
As those 4 square drive screws are exposed, it appears you can remove them, then the front panel, and perhaps the TV should be removable.
Let us know what you find/have found.
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
2014, xlr
