Old 06-19-2015, 07:04 PM   #1
Warm Refrigerator
I have a 2011 Rockwood M2607. I have a question about the Dometic refrigerator. I have the unit on Auto, the gas is on, the battery is at 2/3 full and it is not connected to shore power. The fridge has been on for about 26 hours. The freezer is cold but the fridge is still warm. Any thoughts ???
Mrt2607 is offline   Reply With Quote
Old 06-19-2015, 07:22 PM   #2
Flybob's Avatar
Odds are the fridge is colder than you think. There is not much in the fridge to feel cold if the fridge is empty. Put a few cans of cold drinks ( your choice ) in after about 5 hrs after you start the fridge, then check the temp of the drinks.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-19-2015, 08:08 PM   #3
Warm Refrigerator
Thanks for the reply Flybob. Yes, the refrigerator is empty. Guess at my age I have to thank all the FR forum folks to remind me what I need to do.
Old 06-19-2015, 08:21 PM   #4
Flybob's Avatar
Fridges work by absorbing heat from warm things. When you open the fridge, you let a lot of warm air in. If there is nothing more than the cooling fins and the inside surface to absorb the heat, the fridge will warm. If the fridge is full there is lots of mass to absorb the heat let in.
TST Tire Monitors
2 100W solar panels
Old 06-19-2015, 09:09 PM   #5
Flybob, you are very knowledgeable on this and I do appreciate your input. I have been an RV'r for 40 years and I did not know that. See, you really can learn something new every day. Thanks again.
Old 06-20-2015, 01:46 PM   #6
Cajun Style's Avatar
http://youtu.be/oIJYx5j2nPQ
There are videos 1-20 to help you with your fridge look at all of them they help me a lot my fridge was giving me the same problem as yours now my fridge stays at 34 deg. Make sure you stick with the Ford videos !!
Cajun Style is offline   Reply With Quote
Old 06-20-2015, 01:48 PM   #7
http://youtu.be/2olgFfBEAuo
Old 06-20-2015, 01:49 PM   #8
http://youtu.be/cYKpZdAex8w
Old 06-20-2015, 03:12 PM   #9
mud yapster's Avatar
Thanks I found my drain tube was installed wrong even though my fridge is working ok this fix will help it work a little better.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
refrigerator
