Old 01-24-2016, 04:42 PM   #1
Washer Dryer combo
We're thinking of buying a washer dryer combo for our 5th wheel. ( Stackables won't fit). Any comment pro or con on the combos would be appreciated.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 01-24-2016, 05:33 PM   #2
AquaMan's Avatar
We got one with our new GT and have used it once. Wife was pleasantly surprised on how much of a load it would do. Best advice would be to not do a load before taking a nap or going to bed. That spin cycle can shake things up if you're laying down, otherwise don't notice.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-24-2016, 05:45 PM   #3
If you're going to go with the Splendide combo, get the vented. The ventless takes forever to go through a cycle, is super fussy about how much detergent you use, and the dry part of the cycle wrinkles clothes so badly, even an iron won't take it out. We've had to rewash at home just to remove the wrinkles.
Karl4Cat is offline   Reply With Quote
Old 01-24-2016, 05:53 PM   #4
AquaMan's Avatar
Agree with Karl4cat on the vented model, which we have.
Old 01-26-2016, 09:30 AM   #5
Thanks all.
We've also heard that the run times are pretty long. Any comments on that?
Cathy & Jeff
Midland, Michigan
Old 01-26-2016, 09:35 AM   #6
SYE
SYE's Avatar
I have the LG ventless in my Columbus. It average 3-4 hours to wash and dry a load, I can not just dry a load, I must wash first so the condensate pump will work to produce the heat for drying. I love it, but you need to do a load every day to keep up on clothes. I dont think I will ever own another camper without one. As for the 3-4 hours for a load, what else do you nhave when camping other than time, so it is no big deal.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 01-26-2016, 10:03 AM   #7
AquaMan's Avatar
I have the Spendide, and I'm not sure on run times, but I'm pretty sure you can use the dryer portion without running a wash cycle. You can also run just a rinse and spin cycle. This is helpful when winterizing.
Old 01-26-2016, 10:06 AM   #8
That's correct AM. With the Splendide you can indeed run just a dry cycle.
Old 01-26-2016, 10:13 AM   #9
SYE
SYE's Avatar
Are the splendide units vented, I know my LG is not and it produces heat from the condensate pump, therefore you need water in order to produce the heat so you must wash then dry.
Scott & Vicki
Old 01-26-2016, 10:27 AM   #10
The Splendide can be had either as vented or non-vented condensate dryer like the LG. I have the non-vented condensate type like your LG and yes, it can run a dry only cycle.
