Old 08-07-2016, 01:36 PM   #1
toslow's Avatar
Washing machine vent
Iv'e got CC and notice a smell coming from the closet that houses the washing maching.
i know this happened last year aswell but i forget what pipe the vent goes in and what direction it faces, does it thread in or just set on top of the pipe when parked? any one got any ideas
thanks
haven a blast
toslow is offline   Reply With Quote
Old 08-07-2016, 02:02 PM   #2
clr
Well a washing machine does not have a vent. If you are talking about the vent for the plumbing drain then the pipe normally has a screw in type of plug. If you have a washing machine and the smell is coming from around the water drain hose that is inserted into the water drain just run some water into the drain and it will stop. In all probability the trap has dried out and only needs some water to stop the fumes from coming back into the coach.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
vent
