Old 06-14-2012, 06:31 AM   #11
TURBS's Avatar
Have you tried shutting of propane tanks waiting 30 seconds and then opening very very slowly?
Old 06-14-2012, 07:28 AM   #12
cootr68's Avatar
Have you tried lighting the stove?
1997 Sierra m-27fls tt
1999 Pontiac T/A
2006 flstn Deluxe
2004 Polaris 330 magnum
Bear the Labrador
cootr68 is offline   Reply With Quote
Old 06-14-2012, 10:25 AM   #13
mstell2's Avatar
Ok, I have propane to the stove, checked breaker and fuse, pressed the resets on the outside of tank, and still nothing. When I flip the switch for gas I still do not here the sparker trying to ignite, and I don't hear or smell gas coming out. Maybe it is a relay? Will check voltage when I get home tomorrow.
mstell2 is offline   Reply With Quote
Old 06-14-2012, 12:01 PM   #14
Herk7769's Avatar
Here is what is "under the black cover" The rubber covers are to protect you from a shock. Just push right through the rubber circles until they are "in".
Not that the wire connecting the high limit switch on the left is burned out in the photo. That one the DC (or "on propane") one.
To check that you must remove the rubber cover.
You must also TOTALLY REMOVE power for a few minutes to reset the control board if you had a "no light" condition three times. Turning off the switch (with the red light) will work.
NOTE ALSO THAT: If the high limit switch is open or burned out the red light will NOT come on ever.
ID:	15264   Click image for larger version
Name:	Limit Switch Reset.jpg
HAM CALLSIGN - KC3FFW
Old 06-14-2012, 12:09 PM   #15
mstell2's Avatar
This is my panel, the fault light usually comes on but is not working, I am not getting any fire to the propane valve or sparker, going check hi limit, will let you know.
Old 06-14-2012, 12:41 PM   #16
mstell2's Avatar
High limit switch is getting juice, gas valve is not. Must be the module I see in the wiring diagram. How do I get to the module? Is it behind water heater or do I look somewhere else? I want to test it to see if it is getting juice.
Old 06-14-2012, 01:28 PM   #17
mstell2's Avatar
Bottom red wire on hi limit is not getting the juice, therefore no power to module. How do you fix this? 99% sure that is the problem, have taken everything apart and narrowed it down. Can you change just the high limiter?
Old 06-14-2012, 01:37 PM   #18
Herk7769's Avatar
If you need to replace the entire thing.
RV Services Online - Troubleshooting - Water Heater Service
Some more help.
Old 06-14-2012, 01:39 PM   #19
Herk7769's Avatar
Press the reset at the top of the high limit switch.
If that does not work the high limit switch must be replaced.
RV Suburban Water Heater Thermostat/High Limit Switch | eBay
Old 06-14-2012, 02:24 PM   #20
Herk7769's Avatar
You could bypass with a jumper (Temporarily) to see if the unit fires normally (Make sure it is COLD so it is calling for heat).
If it does order a new one.
led pad
