Old 06-14-2012, 12:28 AM   #1
mstell2's Avatar
Water dont work on gas
Have a 2011 rockwood 8281ss and the water heater is not working on gas, when I turn on the gas switch in the camper the fault light used to come on, then after a few seconds I would hear the gas kick on. Now when you flip the switch the fault light does not come on and the gas does not light. What can I check before I have to send it to a dealer. It works on electricity.
mstell2 is offline   Reply With Quote
Old 06-14-2012, 12:39 AM   #2
TURBS's Avatar
Have you checked dc fuses?
High limit resets?
Old 06-14-2012, 12:42 AM   #3
mstell2's Avatar
The 15 amp blade fuses look fine, saw a reset on outside of water heater but looks like have to take off little black cover to see what that is. Will try to open it in the morning, it's too dark to be messing with it tonight. Don't want to blow myself up, haha.
Old 06-14-2012, 01:02 AM   #4
PrairieBoy's Avatar
Did you shut your electric element off. The gas won't come on if the heater is still being maintained by electricity
Todd & Sheila and kids
Rouleau, Saskatchewan
2012 Surveyor SV-305
2012 Dodge Ram 1500 4X4 CC Outdoorsman
PrairieBoy is offline   Reply With Quote
Old 06-14-2012, 01:08 AM   #5
mstell2's Avatar
Mine works on both gas and electricity, heats the water faster I guess.
Old 06-14-2012, 01:14 AM   #6
PrairieBoy's Avatar
If the water heater is set to electric and gas, I believe that the electric will maintain the temperature in the heater until there is a demand for hot water at which time the gas will kick in to heat the water along with the electric element. I have not done this but I believe that this is the way it works. Correct me if I am wrong.
Old 06-14-2012, 01:45 AM   #7
mstell2's Avatar
PrairieBoy, that sounds correct, but the burner should be kicking on because of people taking showers, but it's not even trying to ignite, don't hear clicking or smell gas. Worked fine yesterday so don't know what would have changed in one day.
Old 06-14-2012, 01:52 AM   #8
PrairieBoy's Avatar
Seems to be an electrical problem then. Turbo seems to be on the right track. Even though the fuses look good, you need to check for voltage with a multimeter. Good luck
Old 06-14-2012, 01:57 AM   #9
PrairieBoy's Avatar
It is also possible that you have run out of propane. If the heater fails to light after so many tries it might go into a fault mode that has to be reset. You didn't specify if you checked the propane or not.
Old 06-14-2012, 05:10 AM   #10
i was thinking same thing as prairieboy are you sure you have propane you wouldnt be the first one to have that problem
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
led pad
