Old 12-15-2013, 08:17 AM   #1
Rocinante's Avatar
Water Heater
New to RVing and have a dumb question, turn on the water heater and it works great. Can't figure out how to turn it off. The switch only says 'on'. It's a Suburban heater. Thanks in advance.
Rocinante is offline   Reply With Quote
Old 12-15-2013, 08:34 AM   #2
wmtire's Avatar
Howdy Rocinate. If you have the dual powered Suburban water heater (electric and gas), then this link may help you understand how each side works independent of each other, as well as how you turn each side on/off.
http://www.forestriverforums.com/for...ore-36197.html
I'm purely guessing, but from the way you are describing, I think you are only switching one side (either gas or electric) on/off and leaving the other side on all the time................since with the dual powered water heaters, both sides can be turned on at the same time.
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 12-15-2013, 01:57 PM   #3
Rocinante's Avatar
Thanks wmtire, the link was of great help.
Old 12-15-2013, 02:34 PM   #4
B47
And Thanks to you for not calling it a "Hot Water Heater"
Old 12-15-2013, 02:45 PM   #5
wmtire's Avatar
You are very welcome. This is one of the more frequently asked questions of all RV owners, and one that many dealers fail to go over in a PDI.
I also sent you a private message to expound on a few more things about this, including amp draw when using the electric heating element.
Old 12-15-2013, 03:48 PM   #6
Professional Curmudgeon
wrvond's Avatar
USS "Myfirstship" had hot water heaters. They were called super heaters. They created super hot steam to drive the steam turbines.
2014 Coachmen Catalina 253RKS
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 12-15-2013, 04:04 PM   #7
B47
Got it - don't think there are any of those in RV's though
