Old 06-11-2014, 07:52 PM   #1
Water heater
I have a 2013 rockwood HW276, I have a power switch that won't light up.. And the water puts out warm water, but won't heat up past the like warm stage. Any ideas as to my problem
dalew20121 is offline   Reply With Quote
Old 06-11-2014, 10:31 PM   #2
bikendan's Avatar
first, you need to post brand/model number of WH. does yours have DSI for lighting the propane side of the WH?
second, for the warm water, you need to check the outside shower if you have one and also the bypass valves for winterizing the WH.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-11-2014, 11:15 PM   #3
Thanks, I'll check in the owners manual for the model numbers. And the DSI ..I checked the area around the WH and didn't find any closed valves. Near the converter panel the is a switch marked water heater..it has a reset switch, the toggle switch is UN responsive and the red light won't light, so maybe it's the switch...
Old 06-12-2014, 12:25 AM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
You want to make sure that your water heater bypass valve and outside shower valves are closed. It sounds like the water in the tank is already hot but is mixing with the cold as soon as you open the hot water inside the trailer.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-12-2014, 02:07 AM   #5
wmtire's Avatar
If you have the Suburban brand water heater, this may help. It's things you need to know irregardless. so you don't damage something.
Suburban's electric switch and much more
As Bikendan and Cypressloser have already pointed out, it sounds like the water heater is heating the water, but you have a bypass valve (or possibly a shower wand on) that is allowing cold water to mix in with the hot water......which is why you are getting lukewarm water.
If the water is already heated to it's thermostatically controlled temp, either by the propane/direct spark ignitor (DSI).......or if you have the electric heating element turned on (unbeknownst to you) if equipped .... then turning the inside water heater switch on will SEEM to have no effect.
The reset light (or fault light) you are seeing, will only light up if the DSI fails to ignite the propane used by the system to burn and heat the water....after 3 failed attempts to light. If the propane lights like it should, or IF the electric heating element is on (you are plugged into shore power and have the outside electric switch turned as explained in the FAQ above), then you may not notice anything just by looking at the inside switch.
To check to see if the water is already heated, go outside the RV and access your water heater. There is a pressure relief valve, near the top of the water heater. Carefully, and make sure you out of the way, pull up the lever on the pressure valve to let water out. If this water is very hot, then you know the water heater is working correct, and it's time to find the bypass valve or shower wand that is on.....which is allowing cold water to mix in with the hot water before it comes out of your taps.
There are many forum threads that detail these scenarios.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
heater, water, water heater
