Old 10-13-2015, 07:30 PM   #1
water heater
a friend of mine has soot coming out of the outside panel at the hot water heater
what can cause it ?
thanks
locogk is offline   Reply With Quote
Old 10-13-2015, 07:43 PM   #2
Canadiancrew's Avatar
Usually spiders or bugs on the air tube resulting in a rich burn of propane without the need air mix. Start with cleaning.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 10-13-2015, 07:49 PM   #3
Spider nets or webs blocking the air tube as mentioned above ... the air tube usually has either slit openings or an opening where the gas and air mix together before the burner itself.
Compressed air to blow everything out (with the gas off) generally cleans it out well.
2009 Salem PT 403FB
2005 Ford XLT Supercrew
Cookies & Chips is offline   Reply With Quote
Old 10-13-2015, 07:50 PM   #4
Roger the above post! Something is dirty and the LP isn't being burned completely, and is emitting carbon monoxide. The average person can fix it. Google it, or check here RV Water Heater Woes
2011 Sabre Silhouette 260BHS
2006 F-250 6.OL
tinkerreknit is offline   Reply With Quote
Old 10-14-2015, 11:21 AM   #5
thanks all
heater, water, water heater
